Hello!
I have a 2018 Land Cruiser VDJ79 that was imported from Saudi.
2 Weeks ago, I killed the battery by accident. My driveway is steep so I just pushed it out of the garage, bump started it (in reverse) and she started right up.
However, the ABS and Trac lights came on. I disconnected the battery for a few hours but that didn't help. I tried a few other methods I found on YouTube but no luck so I went and bought the BlueDriver ODB scanner.
The code that comes up is C1241- Antilock Brake Sys Code: Low or High power supply voltage
I have cleared the code several times but the lights stay on (even with the code cleared) and the code will come back in a few minutes.
Voltage at the battery was 12.8 off and 14.1 while running.
I took it to a local shop and they found the same code and even recommended i replace the battery because it was not correct (amps to low for a diesel) and showing age.
Still no luck. They told me they checked all voltage and everything seemed fine, it should probably go to the toyota dealer. The dealer is 1.5 hours away and always slow/backed up so I'm looking for some help.
I'm kinda wondering if i broke something when i bump started in reverse because now the Hill Start Assist does not work.
