Since I swapped out my cluster lights to blue, I now have an ABS light on constantly. I checked the brake fluid and topped it off, then used the jumper method to pull the code(s) and get code 48.
Search shows (ABS 48 code) a possible CDL short or locking, but I have no CDL switch on my truck (97 LX450).
Doesn't seem to be much info on this and I saw no threads that actually listed the remedy for the code. Can anyone offer a solution? I followed these steps, but I get the code w/o removing the jumper in the DLC plug. I cannot get the light to clear though, it stays on solid while truck is running and just gives the code when jumper is used.
Jumper Tc to E1.
Key on.
Press brake pedal 8 times within the first 3 seconds.
Check the warning light shows the normal code [assuming they mean flash every half second here].
Remove the jumper.
Check that the warning light goes off.
[assume key off here]
When the light comes back on, you will likely want to pull the codes.
For that:
Remove the flat little metal jumper from the DLC plug. Don't drop it. Put it someplace really safe.
Install jumper Tc to E1.
Key on.
Count flashes.
Example: 2 3 would be two flashes, 1.5 second pause, three flashes, 4 second pause, then two - three again and again. Or it might show an additional code and then repeat.
If flashing rapidly without any pauses, it doesn't have a code stored.
Key off, one jumper in, other out, and you're good. Unless you drop that jumper!
Jumper Tc to E1.
Key on.
Remove the jumper.
For that:
Key on.
Count flashes.
