ABS and CDL interaction question
LUGOFF, SC
I've noticed something concerning the ABS and was wondering what the collective minds think about this.
CDL with 7 pin mod.
I exercise the CDL weekly on the local sand roads. Typically I go pavement to dirt at anywhere from 30-50MPH, trigger the CDL, confirm that the CDL light and the ABS light come on and drive a few miles while playing in the sand and then deactivate the CDL just before hitting pavement, again at 30-50 MPH. The CDL cycles just fine. The ABS light though will stay on until the ignition is cycled if I deactivate the CDL at over 30. If I deactivate the CDL at low speed, under 10, the ABS light goes out too.
I have pulled over into the shoulder and cycled the CDL in forward, reverse, neutral to see if the ABS will reactive all to no avail. If I turn the truck off, and restart ABS is back to functioning.
Is this normal or abnormal behavior? I have the distinct feeling this is not normal; it doesn't bother me that I don't have ABS active, just curious.
I never even thought about putting in the CDL at that kind of speed. Why would you do that? I'm sure others will chime in here, but for me, I'm typically stopped (or maybe going slow) when I put it in 4WD.
Aren’t there, or weren’t there, directions on the visor about engagement ? ? I always stop before locking it in too. Just makes sense to me.
CDL with 7 pin mod.
Normal.
O.K. then it's functioning perfectly. As for going from AWD to CDL locked (4wd HI) speed doesn't matter, just slippage between front and rear. Now going from Hi to Lo...absolutly the truck must be stopped.
And I wouldn't engage the CDL if there was slippage between front and rear, with the truck moving.
