Abnormal shifting
denver
93 w/ 156k. After doing headgasket for overheating issue, the cruiser has developed an abnormal shifting problem.
To describe the concern best is that the vehicle has no power off the line and at 65mph the vehicle rpm is at 3000 - 3200. It really works alot to get up to 65 and cannot stay at that speed even on flat highway.
I have checked and adjusted gas pedal cable, trans cable, and have checked the trans fluid. Fluid is at proper level and condition is transparent. I have noticed that when prying the throttle blade fully open that the gas pedal cable has slack. I also noticed that the trans cable has alot of slack even after adjusting it as tight as it will go.
Should I just replace both cables?
