Plenty of reasons I'm afraid. Bolt holes not plug tapped, using old bolts, uneven tightening, faulty torque wrench, slipping belts causing localised overheating, dirt on gasket face, block face not true (unlikely), engine running too hot due to faulty stat, (dumb gauge cannot pick this up), poor quality gasket? It might not be the head gasket, could be a crack? I am afraid the list can fill a page of A4.
If possible check out which cylinder is being affected and drain coolant and oil and dismantle slowly, you may simply put a spanner on a bolt and it's releases with no effort, have the head pressure tested and go from there.
regards
Dave
