aa mounts
spicewood,tx.
bought a cruiser with a already installed sbc. engine turned out to be bad, so built a new one. question- since i obiously don't have the install manual, how tight should i make the mounts? you now, the bolts thru the biscuits, both front and rear. any facts or opinions would be appreciated.
thx jim
Are you using a lock nut? If not, I would find some.
Pull them up tight. No need to ape on them, but make them good and snug.
I would also pay attention to them occasionally to make sure that the mounts have not distorted and the engine is no longer secure, even with the use of locking nuts. This is not an uncommon feature of this style mounting/isolation system.
:beer:
hi a small question. just reinstalled a new sbc in the trucka and it is a lttle rough at higher rpms. pretty smooth most of the time though. just trying to eliminate problems. anyway how tight should the aa mounts be? way tight or just snug? never had an installation book so have no clue, but did crank them down hard which i think could be a problem. any advice? thx jim
poser, thx.the nuts are locking. i think i will back off a bit and see what happens.
also noticed when i put everything together that the e-brake drum wobbled, and todaay while going about 25 , pulled the e-brake handle and felt a very distinct vibration. i can see a place on the piece arond the ebrake where it was hit after knocking a hole in the case and ripping out the drain plug. which led to the changing of the case.
anyway i amin the market for a good ebrake drum. any ideas? next job would be to take the driveshaft and have checked and balanced.:confused:
