AA adaptor V8 to H42, H42, crawl box
Hillsboro, OR
Website
www.cascadecruisers.com
all bolted together and ready for your cruiser.
Have some leftovers from my build so this is what I got.
AA bellhousing adaptor Chev to H42 bolted to the H42, the h42 has the adaptor and 10 spline shaf that t runs into the truck crawl box with 2.28s, got a truck box ouput shaft in there right now to keep everything together. Needs an adaptor and shaft to run into whatever x-fer case you would want to run (unless you want to run a truck box behind this setup?). This was all assembled by James over at Over the Hill. Everything should be good to go.
$850...
oh yeah, comes with the clutch, flywheel, and flexplate.
pics:
pics...
Let me know when you want to split them up. I'm not interested in the H42 with the crawl box set up set up.
Only the AA bellhousing adaptor for Chev to H42, the clutch, flywheel, and flexplate and thow out bearing arm.
I have a feeling this wont go as a whole unit....
Your first in line when it/if it does split. :)
