A442F CDL yes or no?
Haiti
Hello everyone.
I need help to figure out if my transmission has a central differential lock or not.
I own a hdj81 1995 automatic transmission full time 4wd
Engine 1hd-ft 24valve 4.2 turbo diesel
My friend has an fj80 with the same transmission. When he shifts into low range the central differential lock light comes on the dash.
If you have the FT 4WD system then you should have a H2AV transfer case which has a locking center differential. All US models came with this tranfser case and it our configuration was designed to lock the center diff when the transfer case is put into low-range.
-B-
hello beowulf.
this is not an american model. this model is from japan the hdj81 with diesel motor
also. this lc used to be a right hand drive and it was coverted to be left hand drive.
normaly on the driver sun visor there is info about shifting to low and high range.
unfurtunatly this car have it in japanese.
this is not an american model. this model is from japan the hdj81 with diesel motor ...
Yes, I understood that it is an HDJ81 but when you said it was an automatic transmission with a full-time 4WD then that tells me it probably has the H2AV transfer case. If yours has that transfer case then it should work exactly like the US spec 80s (which I described.)
Can you find out what transfer case you have?
-B-
Can you put the gear selector in "N", shift the transfer case into "L" and see if that locked diff light comes on the dash? Maybe it's just late.
