A442F Box problems
Vereeniging, RSA
Hi Guys
I have a '94 VX Cruiser (UK spec) and have had endless sh!t with the auto box. We tow a relatively large sand anchor and the box gets hot. The original box was overhauled and then fixed 4 or 5 times by a local company and I eventually replaced it with an 440 box. This box was also a dud.
After reading about Wholesale Automatics on I8mud I have placed an order with Rodney for an Extreme heavy duty box and heavy duty converter with him.
I have found several threads about guys that have just installed one of his boxes, is there anybody that can give us a long term report on a box that has really worked hard?
I know that it is too late now:o but the box will cost me about AU$10k with duties and transport and I would like to sleep a bit better about the investment:)
Thx
Dion
I'm sure your vehicle would have one, but if not make sure to get an external transmission cooler. If you already have one, it would look like a small radiator in front of the the main radiator and would have lines running to the tranny. Make sure its working as it should. (If you don't have one, Rodney sells a kit, but you could also find one on ebay or at an auto parts store.) You need one either way though.
As far as the luck you had with your former ones, that sucks. What kind of weight exactly are we talking about here? Some say that if you overheat these trannys they die quick, but those with the coolers tend to last a long time. Hope it works out.
Yes I have an external cooler as well, the oil flows from the normal "in radiator" cooler to the "air to oil" cooler. I tow a Conqueror Conquest trailer, you can find them on the web. Weight with water and diesel must be close to 1t. I don't think that these boxes like to pull trailers in deep sand, in Botswana and Namibia you can do 300-400km of deep sand driving in one go.
