A442 failure or?
Nashville, TN
Well, on the eve of our first big trip with the 80 she's laid down on me and the only thing I can think of is transmission. Scenario is:
Never had a problem over the last 4 months.
Drive about 60 miles a day to work 90% interstate.
Today after my interstate trip i stopped at the local grocery and when i was done and went to exit the parking lot into traffic heard a loud bump and no go.
At first it almost felt like a driveshaft, not as extreme of a vibration but there was some.
Tried all combinations of R,D,2, & L; tcase in high and low; CDL locked and unlocked. Nothing.
I was able to slowly move myself backwards about ten feet to get out of traffic, but afterwards all she does now is rev.
Feels like its in neutral all the time. No vibrations at all anymore.
All drive shafts still attached, no holes in anything, looks perfectly normal.
Only thing i can think of is torque converter, maybe pump, output shaft sheared. At this point with being able to very slightly move at first and the vibration, this leads me to converter or pump.
Unfortunately i seem to be the first person with issues with this transmission as i can't find anything similar on the internet. Any ideas?
Drive flange? All I can think of. How does trans fluid look and smell?
All Drive flanges Still good, that was one of the first things i checked. Trans is full of fluids. Fluid did look slightly burnt but not black. More pink with brown tint.
Once here I read of a guy that had the gears of the transfer case ...well...melted to say it nicely...if it doesn´t move. check diff fluid on center diff (transfer for us) if it is not that, then it must be TC
Well, I wanted to update this one what's going on so far.
She's at the shop right now. Pretty sure it's the torque converter that went out. Mechanic agrees. Says that absolutely no drive in any gear sounds more like TC than trans. I guess with 385k on it it's given it's all.
I purchased a good used trans and sent out the converter for a rebuild (found out today no one stocks a rebuilt A442 converter, the one I ordered that was supposedly for the A442 was for an A440).
Going to keep the old parts and rebuild them and keep them on hand for the OM606 swap I'd like to do in the next couple years.
Including labor $600, working used trans $500, and converter rebuild $200 plus fluids, etc I'll be into it for around $1500. Not too bad.
I am surprised as to how poor some of the salvage yards around here are. The one I used to go to before it closed down the guys could almost tell you exactly what you were looking for and where it was and the place I went to this week brought out a 343 and a 440 and tried to convince me one of them was the right one.
