A440 transmission filter cleaning ?
Socal
I have a 91 fj and I'm going to drop the transmission pan this weekend and wondering if I can simply clean the filter instead of buying a replacement?
Ya you could back flush it but just order a new one and replace it with a new gasket. I do a drain and fill every year and replace filter every other year. When the filter is removed a bunch more ATF will drain out about 2 gallons will be needed to refill.
Been using Amsoil ATF with excellent results, the 440F shifts smooth through all gears. At one time it shifting was very rough and had slipping on hills with a full load but no more even though I have 290K miles on this cruiser.
Drain ( just give as long as you can to drain ), 10 mm bolts heads for the pan and the same for the screen ( yes it will make a mess when filter is removed, have some type of tub ect for the ATF to drip into ), Clean the pan and magnets, for the filter it should be a fine metal screen that you can be see and piss away time trying to back flush. Probably the screen will look OK but its best to just replace it and use a new pan gasket!
New ATF fluid could loosen old ATF sludge and restrict or plug the filter off shortly, so just go through the whole process again as needed untile your good with it.
