A wiring diagram to solve the problem of a 1988 Land Cruiser FJ62 four-bulb vehicle, which is that all the bulbs work when the low beam is switched ON
Saudi Arabia
Hello again to the Land Cruiser community, especially the FJ 62 series.
1988 Toyota FJ62 Land Cruiser Wiring Diagram: Solves the problem of all four bulbs working at the same time when the low beam is switched on after replacing the factory bulbs with halogen bulbs, because Low-side switching causes backfeed with halogen upgrades.
ensurin after changing the factory bulbs to halogen bulbsseparate operation of the two low beams, also is that all the bulbs work when the high beam is switched on, In addition to the blue indicator light that illuminates on the old man's car dashboard ;):rofl:.
Ensure that the front light works like the factory system.
How to connect the male wiring harness to the original car plug for the low beam?
to connect the relay kit wiring harness to the original car plug for the low beam.
1. Red (14 AWG) OR (2.5 mm) connects to red/yellow (positive constant).
2. Green (14 AWG) OR (2.5 mm) connects to red/green dotted blue (negative low beam). **(In Taiwanese wiring harnesses, the wire color may be white instead of the green wire color shown in the diagram).
3. Black (14 AWG) OR (2.5 mm) connects to red/blue (negative high beam).
To Factory Connector
Goooood Luck 🤞
Note:
To save time and effort, you can find a Taiwanese wiring harness (SJ-81005 Four-Lamp 12V) ready to power four bulbs. You only need to change the order of the H4, 100/90W male plug wires as shown in the diagram that connects to the low beam plug. **(Images are attached).
