A/T oil temp
SA
Hi all. I have same issue with A/T oil temp in addition the filter light at the same time. I let the car cool down for two days. And start it . Still shows both. A/T and the filter light. I changed the transmission strainer along with the fluid,still the same. Please help!
you might need to post more info
year / model / engine
I do not think any US Spec 100 series has any sort of filter light
1995 Land Cruiser. It is 80 series. Not 100 series. It was a mistake.
Thanks for you reply. You are right. It is 80 series. 1995 land cruiser. If you can assist in telling why the two warnings lights are on at the same time. I would be grateful.
Remove the EFI Main fuse from the fuse block in the engine compartment, wait 30 seconds, reinstall it and see if the lights go out.
