A Pillar Straightening
OGBeno
11101-59235
Moderator
GOLD Star
Patagonia, Arizona, USA
Any suggestions folks on moving my USPS A pillar back to the PS about 1/2"?
Sledge hammer?
Winch?
I need about 1/2" to be able to fit my winshield back into the truck. Won't go in.
Any body work wizards out there?
Thanks in advance.
-onur
I think a sledge would really screw up the pillar. I'd say (and this is just a stab in the dark) sandwich the pillar with a couple pieces of 2x4 and use a stationary object on the passenger side of the vehicle (like a tree or pole) and a come along to pull it gently?
Sledge hammer?
Winch?
Thanks in advance.
-onur
if ya a get portapower kit before sat. if nobody has one in the club that is.bring the 80 to the meeting saturday.if all is up for it.:D i know i am.i have a unit out in the shed.but the lines are all busted to s***
Ram it with a bottle jack and a 4x4. Set the bottle jack on a piece of lumber in the bottom corner and push perpendicular to the A-post. You may need to do some notching on the bottle jack base lumber to keep from damaging the plastic on the door sill.
To keep the bottle jack from kicking out, place a ratcheting strap around it and across the inside of the vehicle, you can attach it to the nader latch. I would probably remove the lid from the center console to keep from crushing it with the strap.
JTK
Stl. Heavy Rescue Strike force member, Missouri USAR team member
JTK
cheaper than spending 100 bucks on portapower
Interesting ideas guys.
I just talked with a buddy and he thought that maybe trimming the winshield to fit the now trapazoidal opening might be an easier option....
Basically, the window guys couldn't finish an install of my winshield because the roof had shifted over about 1/2" making the window not fit.
I am getting the OEM window size glass on Monday and Kirk said that tracing the new opening and then having the OEM glass cut to size and then installed might be a quicker and cheaper option....
THanks.
-onur
JTK
Interesting. You think the bottle jack will have the force necessary to move an A pillar?
Our smallest capacity ram is 6 tons of force fully extended. The bottle jacks that I've lifted the whole roof off of someone with are 10 ton. That was pushing both the roof and the a pillars up. Most bottle jacks should work.
Pushed the roof back up, straightened and took the trapezoid out with a 4 ton port-a-power. We used the new glass as an alignment tool, pushed the roof around until it fit and the doors fit properly.
Everytime I rolled my Toyota truck I would portapower the roofline out and slap a new windshield in. The driveshaft tunnel was the best anchor for me. I wish you were down here I could straighten everything out for ya.
Can you port a power guys give me some more direction on this?
I'm about ready to pull the trigger on a cheap Harbor Frieght model just to do this.
I have the glass coming Monday so I can use this as a template to know how much to push the roofline/pillar....
I'm desperate at this point. I'm half tempted to just put a piece of plexiglass just to get me down to NM and then deal with the issue there...
Depressed indeed.
-o-
Beno,
Cutting the w/s is not going to work. Think about it. Draw a rectangle. Now, keeping the bottom corners in place, draw a trapezoid. See the missing triangle? - that's what you'll have. If you started off with a w/s that's larger than your stock w/s you'll have enough surface but the odds of finding one the right shape are astronomical as in - forget it. Move the pillar.
Pull the PS door off so you can brace against the upper hinge area with wood and padding. Use something like a dowel taped to the dash and stickin up to the roof/A pillar location aligned with a piece of tape on the roof so you can see your progress. You'll pull, then relax and see if you've moved the tape relative to the dowel until you've moved it the amount you want. Diagonal measuring would also do it - pull until the diag measurements are the same and it's square. Hammering on the wad of padding with the cable pulling will also help move the metal when it's under the force of the comealong.
To pull, find a way to brace the upper hinge as noted, then wrap an unused recovery strap many layers thick at the top of the A pillar (or fire hose, or whatever padding strategy you can think of) and hook a come-a-long to it. So, you're pulling the trucks A pillar away from the centerline and the hinge area brace keeps the truck from simply leaning. Maybe you have a handy telephone pole, the corner of a building, etc to brace the hinge against.
I can't think of a way to use a jack as noted above because you need something to shove against. I've used a comealong to straighten a couple cars. Attached the other side of the cars to something heavy (another truck) and pulled big stuff back straight.
DougM
Beno - this will not take a lot of force. Don't waste money on the tool. You've already got ways to place this force on the truck or can get a comealong at any big box store for $50 and it will be useful all your life.
DougM
