A multiple thread QA in one (poser)
Fresno, CA
Ok i have a few questions so here they are.
Recently did a SOA that is not a question but my rear sags compared to the front is this normal? Wheelbase is about 100" front axle under the radiator area. The front springs have a bit of arch rears are about flat. Front and rear i think are stock front is i think 7 leaves rear 6. I amy have to go with extended shackles in the rear which is why i ask.
Front drivehaft has what i consider a s***ty angle. The t case output is basically pointed a few degrees up and then i have my front pinion at roughly 10 degrees up. 350 engine sm465 and 4 speed tacase. Anyways i would say go Cv joint in the front but nobady else is having this problem or at least search doesnt say so.
Can an SM465 input bearing be replaced without touching anyhting else in the trans (?poser?)
I want to get the driveshaft and leveling done before i cycle it to figure out the shocks i need any help is helpful:grinpimp:.
Thanks
The add a leaf that was inside my pack helped level out my ride. A combination of that and extended shackles could get you where you want to be. Or new springs.
As far as the angle of the front pinion, it should be pointed directly at the output flange regardless of the degree number, then a CV joint at the tcase and a Ujoint at the pinion.
Sounds like you've got some work to do...
It is very very common for the rrear of a '40 to sag. One thing that helps is to swap the front and rear springs.
Level your engine/tranny/Tcase so that the T/C flanges are straight, not pointed up-down.
Sounds like you have reversed springs (100 inch wheelbase). If you have not shifted the engine and tranny/Tcase forward, you can use a ujoint at each end. After getting the Tcase level set the pinion level too (actually, if you have not cut and rotated the knuckles, set the caster to about 2 degrees and the pinion should be within tolerances for a ujoint-ujoint setup.
Mark...
well after looking at it CV seems necasary if i ever want my passenger side to drop. The springs seem to be in decent condition shackles i will get tomarrow since i'm in fresno i got marlin.
Seems weird with the spring flip that my spring packs would be so unweighted to unlevel my ride, but i will not go ghetto. The 4" SUA i thoguh was comparable but after a SOA with my rig (1.5 body lift) i can fit 42's on this thing. With my rear sag the 37's look shiot in front.
Hopefully Marlins got a CV for me tomarrow i guess. Gonaa jack my mounts for the t-case (aa)style up a 25-.5" so i get some clearance before i build a skidplate anyways.
Any recommendations are welcome on this topic.
