A locker Question?
STL> MISSOURI
I am looking at this 95 Lc just for the lockers mind you.
I test drove it, the front seems to lock, the light quits flashing ie the light is not flashing on the dash, as is the rear. What is going on? Is this a quick fix? or is a this large problem.
Thanx in advance!!
george
Clarify. The light for the front locker goes solid, but the rear doesn't?
-Spike
Its most likely due to non use and probably just need to be worked a bit (trying to get them to lock while doing figures 8s in a loose dirt parking lot or need taken apart for a good cleaning.
The light for the front locker goes solid, the rear keeps flashing.
I drove in circles mind you but not figure eights, alot of circles.
The truck was locked in low to where I could barley steer it !!
Is this an issue? Should it be that hard to steer? Sorry about the
stupid questions, just trying to better my truck as well as my knowledge.
George
With the front locker engaged, it will be hard to steer. I'd shut off the front locker for your 8's since you already know it works. Then you can hear if the rear tires are scrubbing, indicating that the locker works but the indicator doesn't (as mine works). If it works you should be able to tell the difference easily by turning some 8's with and without it locked. If it doesn't lock, try turning it on and off repeatedly, excersizing the motor- that might free it up. Keep in mind it's an electric motor that wasn't set up to run constantly though, and give it a rest from time to time.
-Spike
George,
As Spike mentioned, it will be hard to steer with the front axle locked. This is a VERY STRONG recommendation to do this testing in a low traction setting; gravel, soft dirt, or even grass (not the local golf course though.)
There are dozens of threads telling how to test and excerise your electric locking diffs.
-B-
Spike another stupid question? This process only works in low?
Correct?
Correct, unless someone installed a 'CENTER DIFF LOCK' switch, in which case you could lock 'em in high. Putting the truck in low range automatically locks the center diff in the transfer case and enables the locking of the two axle diff lockers. Without either the t-case in 'low' or the 'CENTER DIFF LOCK' switch on (if installed), the locker lights will just flash.
-Spike
Thank you for the quick reply Beowulf as you have helped me in the past, I guess I should have have done a search 1st, but I did
not. I will think about it in the future!! Most people (Spike) seem
to be happy to share their knowledge as you often do Beowulf.
George
I'm bored and needed something to do. Usually I'd yell at you about using the search myself, or just ignore the thread entirely. :D Sometimes it's easier just to give the info and add to the myriad of threads that will come up the next time someone searches.
-Spike
Thanx for answering it is alot more personable, I mean I am
getting ready to throw down some cash on this truck for my truck. I am going to buy the truck for the lockers only. I would rather here it from experience than read something wrong!
George
PS: Thanx for being bored
Hey George,
Are you going to swap those axles by yourself? You know there's more than just the lockers that are associated with the swap, right? If you are doing this by yourself, good luck:flipoff2: that is a lot of work. I've got all the bits and pieces but the rear and front locking axles to complete my diff lock swaps. :flipoff2:
It's not all that hard, and not much more work than doing a lift (and a good time to do a lift, if you have the inclination).
Service the axles before starting work on the truck.
-Spike
