I recently put a used F motor from cruiserland.net in my 73 fj-40. I was driving down the highway and the oil pressure was fine until it got warm and was almost all the way to the left. I looked on th internet and found that this is usally normal but it is better to get a mechanical gauge. Someone also posted "to see if you have pressure pull the sending unit and turn the crank to see if oil comes out." I did this and had oil coming out. After this I changed the oil (went to 10w-40 instead of 10w-30) and filter and drove it a couple of miles to my house. The gauge never came up, but since I just checked by pulling the sending unit I didnt worry. Saturday night I put a mechanical unit on the motor and got 0 for a reading. I then pulled the sending unit and turned it over and no oil came out. The thing runs great but I am not going to drive it untill I get an oil pressure reading. Could I have somehow put air in the system from pulling the sending unit and turning it over? Or do you think that the filter I put on is bad. I plan on pulling the distributor this weekend and testing the oil pump. ANy advice?
