The Maggiolina Grand Tour or Airlander are bombproof shelters on top of a vehicle.
The lift Mechanism solidly holds the tent locked tight- drum tight.
The flat fiberglass roof is also solid and NOT hot or cold based on the weather outside.
I felt safer with these on my 100 than with my Tiros or Bibler on the ground. The Tiros and Bibler are popular tents used on Himalayan or McKinley Trips. I used them up Rainier, the Tetons and the Wind River Range during winter mountaineering trips.
Full canvas tents are sketchy - once a pole bends or a side rips, you are toast. This is why I always had a small OR bivy sack in my pack. Having said that, because of the design of the Maggiolina tent models I mentioned above, you do not have the inherent weakness with the standard tent poles and full fabric.
2 very different applications. For extreme mountaineering, you give up size for weight and comfort. You also set these up on the leeward side and have to keep digging it out for snow load limitations.
For extreme overlanding, the magg design gives you stability without using standard tent design- thus can be set up high in the wind. No poles to get bent and limited fabric without many seams to bust.
I am partial since I carry these tents. Actually I also carry 4 season shelters that I rent to clients in their summer trips in the Tetons- where it can snow any given day.
Again, 2 different apps. As we all know, one size does not fit all! This is why we have all the gear, tires, etc that we hoard!
Safe Travels!
