Where do you get the orange hose that goes between the valve cover and the air cleaner, towards the firewall on a 78 fj40? Also I have a leak at the speedo cable on the transfer, is there a fix for this? Thanks, Bill
mobiltoy said:Where do you get the orange hose that goes between the valve cover and the air cleaner, towards the firewall on a 78 fj40?
mobiltoy said:Also I have a leak at the speedo cable on the transfer, is there a fix for this? Thanks, Bill
mobiltoy said:Where do you get the orange hose that goes between the valve cover and the air cleaner, towards the firewall on a 78 fj40? Also I have a leak at the speedo cable on the transfer, is there a fix for this? Thanks, Bill
mobiltoy said:I will try the fix with the rtv tomorrow. Bill
mobiltoy said:Would the heater hose be ok with oil and heat. Also what is the fix for the speedo cable at the transfer case? I know it is leaking there I need to know if there is a fix that I can do. Thanks, Bill
mobiltoy said:Poser I misread your post I don't know exactly where the leak is from, it just looks like it is from where the speedo cable screws into the tcase.
I am playing along but dude you might be wraped too tight. Thanks for your help, Bill
