A cooling system question...
Mound, MN
I'm getting the feeling that reading too much on ih8mud is like reading too much in a medical text, the more you read the more "symptoms" you find, then next thing you know you're convinced you're dying of cancer. Anyway about 2000 miles ago I flushed the cooling system, did the oil change, filter, etc. Over that 2000 miles I'm missing about two coffee cups worth of coolant from my over-flow tank. I should also mention that at the time, I noticed the lines running to the back heater were toast and not wanting to rip up a bunch of stuff, I cut off the line to the rear heat and made a bypass running the fluid back. I have not seen so much as a drip of coolant under my 80, and everyonce in a great while I've noticed a small smell of coolant, though I can be sure it's from my truck. My temp guages are fine, truck runs like I just picked it up at the dealer new, and there's no rough ideling or running. I'm just a little freaked about where the coolant could have gone.
For the record I'm a complete idiot with car repair, and the above items were all done by myself with close supervision of a mech friend who's trying to help me be more self-sufficient. Per him, these things are so easy to work on, you have the full mech manual that gives you step by step instructions, you'd better never have to take it in to the garage. That said, he's on his way back to Alaska and I'm just being a little crazy over keeping this thing in top shape.
Thanks for the help in adance.
Jay
IMO it is highly likely that you didn't get the system completely full and what is missing from your overflow has been "burped" into system :) - I tried to carefully and slowly fill my system up after a flush/fill and noticed after a bit of driving that the level in my overflow tank was down...IIRC I had to top it off a couple times before it stabilized.
Have you topped off the overflow tank? If so, did it go down again? Maybe try the real simple bubble test...Look under the oil cap and radiator cap for tell tale signs of coolant in the oil etc.
Another cheap insurance thing would be at your next oil change, take a sample of your oil and send it to Blackstone for analysis. I'm with you on your comment that the more you read the more symptoms you start to notice...I'm HG paranoid so I've been sending Blackstone a sample every other oil change...
Has the PHH been changed? It can weep/leak and be very hard to spot. My wife's was leaking so slow that it didn't even spot the driveway. It would all evaporate before it left the side of the block.
PHH? As I mentioned I'm pretty new at repair work. THe last car I felt comfortable under the hood was my 1964 Merc, I could damn near stand inside the engine bay. Even then I never did much more than change the oil.
I haven't tried topping off the overflow tank. I just bought the truck 2000 miles ago and I have all the receipts from the PO. I show that a new radiator was installed (OEM) about 30K ago but I had no receipt that there had been a flush and fill since so I went ahead with it. I'll give the top off a try and keep an eye on it. All the other tell tale signs don't exhist. No sweet smelling exhaust, the AC doesn't cut out, no rough running. I'm hoping it's just the coolant getting sucked in and settling.
I will also send in an oil sample as well, any info on how to go about that?
Jay
Jay
Blackstone Laboratories - Gas Engines
At the bottom of the page you can click on a link to request they send you some free sample kits that you use to collect and send in the oil sample. Follow the instructions and go from there :steer:
Hadn't considered the PHH but Grench is right...Unless you know it has been replaced I'd check it...Just do a search for PHH and you'll get a LOT of info :D...I've done 2 and IMO they are a PITA to do but worth it for the peace of mind...A LOT easier to do IMO with the starter out so while the starter is out you may as well do the starter contacts/plunger etc. rebuild on that. You don't have to drain the system but you will loose 1/2 gal or so of your antifreeze (more if you don't leave the radiator cap on :hillbilly:).
To save you some searching you can get hose at NAPA etc. but many like to get this stuff:
Silicone
Grench and Corsair: ease off a little. WTF - can't you read? He doesn't have much confidence, his mechanic friend is out of town and you're sicking him on the PHH and starter contacts?
mnflyfish or Jay: Just top off the over flow tank. By this I mean add 50/50 mix of coolant and distilled water to bring it back to the 'Full' mark on your overflow tank. Do this when the engine is cold - like in the morning before you start it up. then drive it for for a few days and re-check it cold in the morning. I'm very confident that corsair called it in post #2 - cooling system had just not been burped.
PHH and starter contacts would be a good project when your friend gets back. I agree with grench & corsair, it needs to be done - but IMHO from what I'm reading in your posts, these can wait. Keep us posted on the results or if you need more help! Good luck.
Thanks! I WAS hoping to break myself in on an oil change, then move on to Diffs. The hope being that someday when something really goes wrong I'd have worked myself up. Over the weekend my buddy and I installed a new antenna, the old one had a broken line somewhere deep. Taking off the dash to get to the radio about put me over the edge. But it's done and I can listen to the radio so check one on the DIY scale.
My first project will be to change everything over to synthetic. Then perhaps I'll tackle the starter and PHH. It is great that there's a site like this, I wish I would have found something like this for my previous cars/trucks. I could have saved a boatload on repairs and mait.
Thanks again, I'll top 'er off tomorrow morning and give it a shot.
Jay
Good point. You're right of course. Top off the coolant tank with some distilled water (since we don't know which coolant is in the thing). Wait for your mechanic. I have had several days/projects where I've wished I had done just that.
....... Top off the coolant tank with some distilled water (since we don't know which coolant is in the thing).......
Excellent point, grench!
Jay, be sure to add the same coolant as you are now using in the cooling system. Hopefully you still have some of what you've already used. What coolant are you using, BTW? There are plenty of threads to search on for good reading and info. But basically, you do NOT want to mix the Toyota red with any other coolant. If that's what you're using, add only Toyota red coolant 50/50 mix with distilled water. If another brand, stick with it.
