A/C troubleshooting
RDU, NC
A/C on my 95 is not blowing cold air. When I turn it on, the A/C idle up circuit doesn't change the idle.
I was reading the wiring manual and regarding A/C operation it said that if refrigerant pressure is "abnormally low", the compressor won't kick on. So then if the compressor won't come on, the idle-up ckt shouldn't kick in, right?
I will check the refrigerant pressure asap, I don't have anything to do that with right now (any home-brew suggestions?). But before spending any money, I wanted to check if there are any other simple things to check (fuse is good) to isolate the problem.
TIA.
Start w/ the freon level first. If it's low then it will not come on to protect the compressor. The low pressure switch opens the circuit to the a/c system below a specified psi,something like 30psi(Don't hold me to this)but start w/ that and let us know.
You can try to run the truck with the AC on and look at the sight glass for signs of bubbles or any flow indicating that there's freon in the system, but my guess is that you won't be able to see anything. A full system and an empty one look pretty much the same thru the sight glass.
You'll need to borrow or buy a set of manifold gauges to check the pressure. The compressor won't kick on unless there is some minimal pressure in the system. That pressure may be in the FSM, but if memory serves me correctly, the compressor comes on at somewheres around 10psi (low side).
If you are in RTP, shoot me a pm this weekend. I'm just off I40 exit 270 (15-501). I've got a set of gauges we can hook up and run through a base line check of the ac system. Should be around the shop sat morning for a bit, but if that doesn't work I'm sure we can figure something out. Cheers, James.
