A/C recharge
From the other thread, mine is a '94.
You have 134 most likely. If you don't have a sticker, look on the passenger side, under the hood, near the compressor for 3 caps on metal lines, remove one, if it looks like an adapter or chuck for an air hose but larger, you have 134. The R12 systems have screw on fittings, and both are on the manifold plate on top of the compressor pointing toward the fire wall.
Charge is 1.94lbs or there abouts if 134, which it should be.
