A/C Hose, Pump Care
Humboldt Nation
I've taken the AC pump off and it probably won't go back on for another month or so till we get the new engine in. What kind of care should I take for the compressor and hose ends or are they ok just left open if kept dry?
Thanks,
:cool:
I would take the opportunity to flush the system. Remover the dryer, run some solvent flush through all the lines, and drain the compressor of all the old oil. Then I would put fresh oil back in and charge it up when it gets slapped back on. Some people will tell you to change the dryer, it's your choice really, but they are only $15-20.
Of course you will want to replace all the o-rings where you have opened the system, but do not install them dry, rub some oil on them first.
Outside of not doing that, just plug the holes.
This is just for now. I've threaded some shop towel into each hole. AC, PS and tranny lines. At least the crud will be kept out.
A flush sounds like a good idea. I'd planned on suckin' the AC out real hard with a vacuum pump. I'll be refilling with 134A.
:cool:
