A/C / Heater blower
Niceville, FL
!997 80 Series. The AC/Heater blower motor is stuck on one speed (low) no matter which of the speed control buttons I push. The blower does shut off when no button is pushed. I just had the Evaporator replaced (leaking). The AC and heat work fine, otherwise. The shop says the blower resistor is good. Has anyone out there seen this problem?
I know on my 94 this happened.
There is also a relay that is located up in the dash above the blower unit.
It is tucked up in there and is a pain to get to.
When I finally got mine out I noticed that some of the plug terminals were cooked
I cleaned then all up and plugged it all back in and all my blower speeds worked again.
The relay is hard to describe, it is a little smaller than a pack of cigs if I remember correctly.
It is worth investigating
I know of a few others that had problems with that relay.
I do not know if it is the same in a 97
This is the EXACT problem that I'm having with my 96' FJ80. The fan only blows on the "low" setting even if you push the medium/high buttons. It does turn off and all the other controls appear to be working normally.
Is the above post referring to the AC AMPLIFIER which is directly behind the glove box? (9 pin connector) It doesn't sound like it but the description is pretty vague.
If anyone has some insight on this please chip in. I'd love to get this working again.
I did a complete overhaul on my A/C last year. I pulled the A/C unit out of my truck, cleaned the internals and replaced the expansion valve. After I buttoned everything back up and turned it on it did the same thing as yours. There was a plug, on the main A/C housing where the evap/cooling unit is, left of the blower motor, that I forgot to plug in. Once I plugged it in all the speeds worked properly. The black plug marked 3Q.
I have double checked all the associated electrical connections and that one is plugged in. These electrical gremlins are a real PITA
There burned up terminal is #3, that's the ground for that circuit. I would check the ground to the body before you reconnect everything. Looks like it's in the right kick panel. Also the circuit is tied into the left kick panel ground (IE and ID on the attachments).
Blower Resistor shares the same ground. Grab the blower resistor from the junk yard while you're there or at least check yours as posted above.
All of this is connected to the IG1 connector (see attachment). Might be worth checking that connector for damage.
Generally, I think when something burns up like that it's a loose connection. But it's worth checking the harness around the area.
