Well i finally got the ac in my pig working . took the 100 v8 compressor and mated it to the stock 71 55 ac . used a condenser from ackits.com that fit in front of the stock radiator and bent up the lines .
This proved that i needed a fan shroud , at idle the high side pressures would go to 390 and higher , but when i put the shop fan on it it lowered to 310 and stayed . So i spent today making frankenshroud out of a bj70 one . which i hope will do the trick as i am out of real estate out front to put a electric one in .
I also plugged up all the holes in the floor and used some Ceramic imbeded paint they use on the space shuttle to controll some of the heat on the floor boards , then cut up a welding blanket for added insluation .
That leaves me with how to speed up my aneimic blower fan , I allready swaped a bj70 one in with a larger squirrle cage but i still want more !. i got some fan speeds off granger and wonder if i could just use a step up transformer .
all in all it is good and cold but still a work in progress
fj55-100
fj55-100
