a/c diagram needed.
Saratoga Lake, NY
I'm one of those who hasn't downloaded the manual...yet!
Can someone point me to a diagram of the A/C unit so as to find the leak points.
Thanks much.
I took a quick look and did not find a comprehensive diagram. Check the high and low pressure valves on the compressor for leakage. You can rub some spit on them to see if it bubbles. Also look for grime or oil at the various connection points. Oil will most likely seep which attracts dirt. You can also get some flourescent dye and put in the system.
Thanks, very much, John_Eckels.
