A/C Cuts Off
Al Ain, UAE
I read with interest threads on engine temps, and louvres, and fans - really cool stuff, but a bit beyond me.
My questions are:
Does your stock 80 come with an electric aux fan on the front of the condenser?
Does this fan cut off automatically when the temperature gauge reaches a certain high point (like after idling with A/C on)?
What happens on Elsie is that the aux fan comes on with the A/C, but after idling a bit and the gauge reaching about half, the fan shuts off and the A/C blows hot air... after I drive on and get some air flowing in and the temp drops a bit, the fan re-starts and the A/C starts blowing cold again.
BTW, fresh hoses and recent flush, with Toyota red coolant.
US Spec 80s do not have that fan unless it is added. I don't know how yours is wired, but ideally, I think it should be activated by temp and compressor cycle, but it sounds like yours is only working off of temp. If you have an EWD you can check the power sources, and you might have a bad relay from the compressor, or you may need to add one...
I hope this helps,
Dan
There is a temp cutoff that will turn off the compressor when you get to 226*F.
Are you sure you have an aux fan? Or are you just hearing the engine rev up a bit when the compressor kicks in? If your gauge is literally at half, you are overheating. The stock gauge will sit just below the halfway mark when at normal operating temp. That's why you get hot air, and as you drive you cool things down again which allows the compressor to kick in again.
could also be that your A/C is running low on refrigerant and will stop after a while? there is a pressure switch someplace IIRC and probably a temperature control too?
OK, thanks - that must be it. I need to check the radiator for loss of pressure.
:grinpimp: Yeah, bud - it's linked into the A/C. Whenever the A/C is on, it's spinning.
Have you replaced the fan clutch for the main fan?
Buck Buchanan
trouble of course is that you may not see the temp needle move at all at 226, dang thing...
easy to find out if you have a multimeter that can read temps, just stick the probe on the big return coolant hose. Or get a cheap thermometer and stick it on there and see what kind of temps you are seeing.
but to reach 226 just at idle, something would have to be very wrong. pretty unlikely I think
This is a good lead - let me follow it up with some searching. The main fan does spin at idle, but it might be slipping or something.
Refrigerant was filled two months ago, and it only happens when the gauge hits half-mark after idling for a while. So the link is temperature rises - A/C cuts off - aux fan stops (since it's linked to A/C compressor), so first course of action would be to check the overheating.
Having said that, at regular operating temp in the daytime (damn hot already!) the gauge is less than a quarter up. When idling in the sun, it goes up to about half - is that not normal? Then it goes back down to 1/4...
well then, your gauge is not the same as ours (US) where 1/2 is normal so could be indeed too hot. But if you overheat at idle that is not good at all.
I imagine mud may be unknown where you are, but may also want to have a look to see if rad could be plugged with gunk?
Still a bit of a mystery - main engine fan checks out alright (doesn't spin easily when switched off at operating temp, doesn't move at all on its vertical axis), thermostat checks out OK (lower return rad hose gets hot so liquid circulates).
I asked a local radiator shop, and they said it's the wiring to the aux fan - though I don't get it as an electrical prob would not only happen when hot) but re-wiring was easy and so that's done.
I'm sure the set up is different for Gulf specs, after all it's one of the hottest places on Earth. At normal operating temp the gauge is 1/4 definitley no more than 1/3 up. When it gets hot it goes up to 1/2, never anywhere near the red line. I don't think it's overheating, it's just soaking up the increase at idle.
Now I'll see if the re-wiring worked.
there are about six or seven different things that either alone or in combination will cause your A/C to shut off.
in your situation, I'd bet it has to do with the engine temp sensor...
it used to happen on mine when the engine would get too hot.
