A/C Conversion Problem
Oregon
The A/C on the '93 I bought does not work. It had a quick connect on the low pressure side and a Schrader on the high pressure side. After asking on the forum if this was a possible factory setup, I was told that it was not. So I figured that someone had tried a quick fix by putting on a quick connect and squirting in a can of something. Anyhow, I assumed that this was messed up and am attempting to do it right.
So I basically took the system apart. I replaced all the O-rings, put an adapter from Schrader to quick connect on the high side, and cleaned out all the lines, condenser, evaporator, and compressor with A/C cleaner. I replaced the dryer and the expansion valve. While the compressor was off, I replaced the square O-ring and checked that the clutch engaged. Putting my finger over the port and turning the shaft, it appeared to pump out air.
I put the entire system back together after adding about 7 oz. of PAG oil. I drew a vacuum on it for an hour. This took it to -30 on my manifold gauge. I then shut the valves and let it sit for two hours. The gauges didn't go down, so I thought I was golden. I added my first can of R134a. I then closed the high pressure side, tapped the second can and started the cruiser. Turning on the A/C, the clutch kicked in and the second can was soon empty. I tapped the third can and started adding it. Things should have been good at this point, but not so. The air was not blowing cold. And my gauges showed only 90 psi on the high side. When I revved up the engine some, the low side dropped to 25 psi, but the high pressure side never went up.
So, is my compressor bad? What else could it be? And if I order a new compressor, which one do I get? I understand that they may come with oil already in the compressor. I sure don't want to get one with mineral oil in it but need one that fits my year. TIA.
If your pressures are 25 PSI low side and 90 PSI high side you're undercharged, you should be able to add more 134a. Did you try putting the 134a can in warm water?
I did put the can in warm water and all three were basically empty when removed. They were 12 oz. cans. The air doesn't blow the least bit cold either. In fact, it is warmer than ambient.
I'd add some more 134a, its odd to need more than 3 cans but those pressures definitely indicate an undercharged system.
I squirted in about another 1/2 can. I get about 40 PSI on the low side and about 100 PSI on the high. However, I now get cold air! Not freezing cold, but in the low 50s. I'm wondering a couple of things:
Could my high pressure reading be off because I'm using a "conversion" connector on the Schrader valve? Perhaps it isn't pushing in the valve stem all the way? I hooked my gauges up to my Subaru, which is stock R134a, and got over 200 PSI on the high side. This means the gauges work fine.
What should the readings be (both engine running and engine off)?
Should I add more refrigerant? Can you add too much?
TIA
You can add too much refrigerant, doing so will reduce the performance of the system and put extra stress on it. Its very unlikely the conversion kit is interfering with your gauges' ability to measure the pressure, I wouldn't worry about that.
The pressures depend on temp and humidity but should be around 30 psi low and 200 psi high and will increase with higher ambient temp The readings should be taken with the engine RPMs around 1500. With the engine off the high side pressured should be the same as the low side pressure (or very close), the actual value isn't really important. If your pressures were taken at idle you should measure again at ~1500rpm.
A low side pressure thats higher than normal coupled with a high side pressure thats lower than normal (your symptoms) generally indicate a faulty compressor. Hope this helps.
When I did mine, I had the system evacuated first. Then I did a fresh fill using a kitchen scale measuring the amount of R134 I put in and did it to the exact amount specified under the hood. The FSM method of "looking for bubbles to go away" didn't work for my truck and led to an overcharge. It cools perfectly after doing the weighted method.
-Phil
(Working on this with cruzerman)
What happens to the pressures if overcharged; ever increasing high pressure, high pressure plateau or would it start dropping on the high pressure side? Do we already have too much refrigerant in the system?
At least it is working somewhat now.
So, I put a little more refrigerant in and now it works great! I actually saw temperatures in the 30's at the vents (but it was only in the 60's when I did this). My main problem was my high side reading. While the system is now working good, I never did see what I should on the high side. With things working, I can only guess that with the quick connect adapter on the Schrader valve, the guage isn't pushing down on the valve stem completely, resulting in a lower than real reading. Anyhow, things now working. I think I'll do a little write up in a different thread.
Thanks everyone. I am stoked that it now works and seems to work well.
Glad you got it working, what are your pressures now?
When you replaced the expansion valve did you replace it with an R-12 valve or a R-134a valve? The valves have different part numbers but appear to have the same external dimensions so I'd bet they're physically interchangeable. I'm wondering if the valves are set to different specifications (i.e. one will "open" more than the other) so that running R-134a in a system with an R-12 valve would result in the pressures being off.
