A/C Conversion HELP!
El Paso
Hey everyone,
Recently I repaired my a/c with a great guide that is posted here on the forum but I have several doubts though. I also did the aux fan mod over the condenser.
Doubts:
1.- If I went from R12 to R134a do I have to replace the cut off switch?, if so do I need to evacuate the system before I do so and why do I need to replace it?
2.- My system cools efficiently but sometimes when the truck is stopped even with the aux fan on it doesn't cool as much as I would want it to, I know the boiling points of the refrigerants are different so do I need to get a new condenser?, if so which one?
I live in EL PASO and it gets really darn hot out here so I appreciate your help.
I have also noticed a small knock after I have the a/c on for sometime, it comes from the engine and it only does it under load, it doesn't show signs of overheating but could this be timing?, Valve adjustment? or could it be overheating without me knowing?
The gauges are normal.
No on the cut-off switch---the pressures are pretty close to the same the switch should be ok.
No on the condensor---if you were to change condensor sizes you would then need to change evaporator sizes.
The only item that might need to be changed would be the expansion valve/orfice tube and receiver drier(maybe lines if they start leaking, typical on a r-12 to 134 change). The two refrigerants and oils are not compatable and any oil left in the receiver could cause decreased efficiency.
Bottom line 134 is not as efficient as r-12 and will probably never work as good as it did with the r-12.
If you change out the drier and expansion you should notice a difference. Especially if they are the original ones. Which guide on mud did you follow? I have not done this process on my 80 yet, but did loads in high school/college with really nice results. Unless you notice a degree or two differences, you almost dont notice a coolant swap if done just right.
First of all, thank you for getting back to me.
I Changed the Dryer and also I installed a brand spankin new expansion valve, I mean it does cool especially when running on clean air but I guess it will never be as efficient when it comes being stuck on traffic, let me find that link for you and post it, I was able to use that guide and change my expansion valve, it was rather easy, I think it only took me an hour or two. I also cleaned my evaporator because it was stuck with debris well more like fully clogged, it was really bad.
Everything seems to be working fine, I have no leaks and it does cool down those 110 degree days, my main concern was if I needed to change the expansion valve. I only ended up spending about 105 dlls for the whole enchilada including the r134, dryer, expansion valve, o-rings and labor(my own). I got a quote from a couple of shops and they are out of their minds, it isn't that hard to get the evaporator out. Give me a few minutes and I'll post the link so you can take a look at it.
*puts HVAC hat on*
Oh yea, we will charge you, and your going to like it because you want cold air.
*hangs hat on wall*
Yea, HVAC seems to be one of the field where you can charge a good mount. HVAC (either auto or building) can be a piece of cake, or a PITA for the same job. Just depends on what/where the unit is. A shop I worked with priced stuff out decently when he knew it would be a simple job. If it was a vehicle he had never worked on before (or a known PITA), he planned for the worst and priced accordingly. But usually you are paying for their experience, and to payoff their new equipment.
I'll appreciate the link. I didnt find much of a guide last I searched. I was wondering more of known problem areas on these 80s (if any). Im just happy we dont have Ford's "Black Death" sludge problem. Thats $$$ and then some more $$$.
And yes, if your stuck in traffic, just about any A/C system is not optimal. A pusher fan helps (thinking about that too), but your still only moving the HOT exhaust from the car in front of you.
I did the pusher mod too, I installed a 14 inch procomp fan with a relay that will throw the fan on once it reaches a certain pressure and it will stay on for a few minutes after you turn your truck off with an after run feature, that runs you about 78 dlls if you do it yourself, it does help a lot when you are stuck in traffic.
Here is the link to the post, I hope it helps:https://forum.ih8mud.com/80-series-...-cooling-unit-evaporator-expansion-valve.html
Do you think if I go back to R12 will my system be more efficient?
There is also a post with the fan mod, if you want I can search for it and send it to you.
Do you think if I go back to R12 will my system be more efficient?.
First concern would be, Where do you get r-12? and then how much are you going to pay for it?
I would stay with 134 if nothing else for the above reasons. The gains to going back would most likely be minimal.
Ditto. R-12 can get costly depending on region. And converting back would also mean you need to change oils, seals, maintenance connections again (more work than its worth). Your never going to be able to hang meat in the 80, but if you apply sound deadener/heat barrier on the underside you can get close. I did and I feel no heat from my transmission or anywhere on the floor board. Im sure coating the roof would help as well. Our Texas summers are killer.
...Your never going to be able to hang meat in the 80, but if you apply sound deadener/heat barrier on the underside you can get close....
I agree/disagree. Sound deadener and heat barrier make a huge difference, especially on the PS floor board. Even without cats and with plenty of insulation above and below the floor boards, my PS foot well gets warmer than the DS.
Here's what I did to get my interior temps down right chilly. I recently replaced my evaporator (the fins were extremely plugged and it wasn't worth my time to clean). I also replaced my drier and o-rings throughout the system. When it came time to charge the freon, I used the synthetic stuff. First thing I noticed was the compressor would cycle more quickly than before and the JDM fan would not come on (triggered by the line pressure switch). The next thing I noticed was how :censor: cold the air was! The new evaporator meant I could move more air through the vents. The synthetic freon allowed the system to run less before the temp probe in the evaporator would shut the compressor off, instead of the high pressure switch (which is why the fan didn't come on)
This was all in an evening when the ambient temp was around 80. Fast forward to last Monday when it was 108 here in Phoenix. The fan finally came on, but the compressor would still cycle more often. My vent temps were around 40-42 degrees. So I opened the evaporator housing and moved the temp probe away from the evaporator about two inches. Below is the result:
Technically speaking, I think that is cold enough to hang meat:hillbilly:
My 80 has suddenly become much more enjoyable to drive in the Phoenix summer [STRIKE]inferno[/STRIKE] heat. In fact, my oldest daughter who always sits in the third row, kept asking me to turn the air down because it was too cold back there.
Thank you all for the advice, it seems I'll be keeping my current system as is, I'll probably move the temp sensor away a bit as well, where did you place it?
Instead of being inserted in the evaporator you took it out and placed it inside somewhere else?
My compressor also cycles more often than before and it is doing a good job on keeping temps but I think I will also change my evap next summer.
Is there anyway of moving the temp sensor without taking everything apart and having to evac the system?
I will do a temp test tomorrow with a thermometer and post a pic of current vent temps.
You don't have to move anything, get the pressures right and it'll freeze you out. I'm impressed to see someone here that has retro'd and blowing 35. Good job.
You can get to the sensor by cracking the evap housing open from the back side (in front of the glovebox).
Read Tx Cruiser's A/C posts and you'll soon see my fix is the :hillbilly::hillbilly::hillbilly: method. His are based on experience most of us don't have when it comes to A/C systems.
I think TXCruiser had a detailed guide on here which gave the PSIs as well.
gotmud - Yea, thats cold enough and I guess technically able to hang meat. Before my freon lost its charge I had 34* while driving down the highway and about 40* at a hot redlight. I am about to clean my evaporator in hopes of temps like that (then 134a as well). Nice!
