A/C condenser?
Saratoga Lake, NY
Is an A/C condenser a buyable item? Should I just call CDan and order one?
I just had the a/c checked for leaks and was told the condenser was the problem.
Not surprising in a truck your age and region (didn't you used to live in PA?). The replacement is very easy. Basically just pull off the front grill and the crossmember in front of the radiator, then disconnect the condenser and remove it. You'll probably want to replace the drier too when you do this job.
I had to replace mine this year and found it was coming apart at the seams. Salt is not my friend :rolleyes:
While you've got the A/C system open, you might want to replace the expansion valve also....my condenser and valve went out at about the same time.
Someone more knowledgable on AC systems should chime in here.
Thanks Tom, I'm not from Pa, but I purchased this 80 from Pa about 2 years ago. No salt there, but where I am ( New York) there is some and I garage it which is good and bad. So, I'll replace all thanks for the reply.
I wanted to get the a/c fixed to take the wife on a little road trip in 2 days. Thinking about it now, snow is almost here!!!
ok, thank you....
Thanks again you guys. I'm looking for a diagram for the a/c unit with part numbers for the expansion valve and condenser, and dryer. Anyone able to help?
SWEET! Thanks much TLC cool find!!!
Are you sure it's the condensor? Do you see a oily spot on it? None of our L/C's have lost a condensor. Might it be an o-ring? I'd look a bit closer. Look for the aforementioned oily black spot at every fitting, especially at the dryer b/c yours is underneath, unlike the 91-92.
You can get run through the ringer at some a/c shops when a simple o-ring is the problem. In my case this summer, it was an o-ring, but the customer brought the new part, and I installed it and kept his perfectly good condensor. They wouldn't have anything to do with me telling them it's the not the condensor. Customer: "It was in an accident, it's leaking at the condensor." Ok, whatever you say.
I'll definitely take a look at it. I haven't ordered anything as of yet. Thanks for the input!
For reference reasons.... :)
Right in front of the radiator, has a little bend to it in the middle at the bottom.
The picture is stock, if you go aftermarket, you better make damned sure you buy one that has just as many rows of horizontal tubing running through it. Less surface area to cool the freon just doesn't work!
Thanks Beno! My first call would be to Dan anyway. Ya get all the right pieces...I don't do aftermarket well.
One thing, use new AC o-rings on all items you replace. :bang:
Basically if it had a o-ring replace it.:clap:
Good luck.
