A/C compressor Spews
ClankBang
Internet Excogitator
Home of the Cast Iron God
I searched the forum and looked in the FSM but I can't find my answer. There has been a couple of times now that my A/c compressor has made an extremely loud whistle/screech sound and spewed green stuff out over the engine. There appears to be a relief valve pointing toward the engine just below the ((high pressure schrader valve?) the one closest to the engine). At that (Valve?) the green (possably died rifigerent) starts spewing out.
You got it - replace the schrader valve innards. Kits commonly available and are specific to AC. Hopefully that is all - but it is possible you have pressure issues causing the problem too. Replacing the valve is cheap but will require the system to be charged, during the recharge you will discover any other issues.
Hi,
It sounds like the high pressure relief valve (commonly known as a 440 valve) is opening. Usually this is due to excessive high side pressure-possibly an overcharge, a restriction or lack of airflow thru the condenser (clogged fins or weak fan clutch). If the 440 valve were bad, it would stay open and release all your refrigerant, which tells me that this is a pressure issue, where it's opening to let excess pressure out, then closing. If you have a gauge set, watch the hi-side pressure while at high idle and see if the pressure heads noth of 400 psi. If it does, shut the a/c off and find out why before it blows up the discharge hose or worse.
Hope this helps,
Rex
Hi,
Hope this helps,
Rex
Is there somewhere I can buy this 440 hp relief valve? I think mine is leaking (not from to much pressure)
