A/C compressor help
So I just replaced he A/C compressor, clutch, and idler, all new from Toyota. followed all instructions, added about 1 to 1.5 ozs oil to the compressor. Then took it to my Brother-in-Laws shop, and filled it up with freon. Turned it on, after about 20 seconds of running and blowing cold it started sqeeking very loud, followed by a god awful noise and the smell of burning rubber. The new compressor/clutch totally froze up. Anyway, I have a replacement coming from Toyota.....But could I have done anything wrong installing it? It was pretty straight forward....or is it bad luck of the draw? Any tips?:bang:
Did you drain the oil out of the old compressor, measure what came out and add the same amount to the new one? If not, you probably ran the new one dry.
Also, did you replace the dryer? Flush the entire system?
Depending on why you had to replace the compressor, there may have been debris in the system that the compressor tried, unsuccessfully, to compress.
Just a stab in the dark, but those are common issues.
The system started chirping very faintly at the compressor, then got loud after about two weeks, and would only chirp when the AC was on. .the dryer was replaced about 3 months ago since it had a leak at one of the o-rings. The system was evacuated, leak tested, oiled, and filled by the machine at my brother-in-laws shop. So I suppose it was done right. :confused:
Did you space the clutch from the compressor correctly? The clutch and compressor are spaced by some shims that need to be exctly within spec. for everything to work correctly. You should have gotten some shims in either the clutch box or the compressor box (more than likely the compressor). You need to get a metric feeler gauge and space everything (stator, magnet, etc.) correctly for everything to work right.
1-1.5 oz of oil seems a bit low for a new compressor. i think my FSM says 4.1oz for a new compressor and up from there (by like 0.5oz or so) if you replaced the dryer or condenser, or evaporator. but i second beno tho, make sure you get those shims in there to spec. you probably have a shim (or 2 or 3) in the old nose if some didn't come with your new compressor. mine did not come with my clutch, but were with the compressor, fyi. and i used all 3 shims in mine to get it spaced right. you probably know this, but you'll need 12-v power to the clutch before you measure the spacing. i just went through this a few weeks ago and so far, so good.
Is the shimming process covered in the FSM? I don't have mine with me at the moment, but I will be replacing my compressor in the coming weeks with a used one. Can I reuse the shims from my current compressor?
