A/c clutch replacement
The pulley bearing is Santech #MT2027 dimensions are 52mm OD x 30mm ID x 22mm wide.
My A/C sounds like it is eating itself alive, I would like to try the bering replacment before I have to replace compressor, and other associated parts. Is there any instruction on how to replace this bearing, I have no experience with A/C clutches at all...Thanks, sorry to mildly hijack
There's a pretty good video on YouTube ( ) where a guy replaces the bearing on a similar compressor in a Corolla. I found that to be useful when replacing mine. I was able to remove the clutch by pulling the compressor from the engine, but still working in the engine bay with the hoses connected. I removed the radiator expansion tank to give enough room to to work.
