A/C circuit
NE Texas
Still trying to get a few things worked out to finish up my 6.2 diesel conversion. I am working on A/C circuit now. My question is I am not getting power to the wire going to the compressor. I am thinking it won't get power unless the A/C has a charge. I notice on the diagram the wiring goes through a pressure switch. It makes sense that the compressor would not come on if there is not any pressure, am I correct in my thinking, or should I be getting power out of the wire with the ignition on and the A/c switch on?
Rusty
Yes, the pressure switch will kill power to the compressor. I believe it has both a low pressure and a high pressure cutoff. The switch is (was) very easy to access. On a 97, it is at the very front of the engine compartment, USDS, and is installed upside down on the line. Connector comes off easily if you want to jumper out the switch for troubleshooting.
Thanks, I was considering jumping the switch, or just checking to see if there was power there. My wiring diagram says the dual pressure switch is on the right front fender and there are a couple more switches/relays on what they call the I/P, any idea what that is?
Rusty
