I have an 88 4Runner, 22RE, fuel injection, all stock.
Problem is the A/C will not cool. Compressor will not engage, probably due to low pressure in the system (fan is on). Can not see any bubbles or fluid movement in the dryer sight glass. I can jumper the compressor clutch and that works fine, still no decrease in air temp when ran that way.
So, I went to fill the system. Had to get an adapter to put the R-134 into it. The adapter can be screwed onto the low pressure fitting, BUT, the quick disconnect fitting from the charge system can not be connected to the new fitting. Right size, fits the adapter, there just is no room to get the quick disconnect under the EFI ducting to get it attached.
Does anyone have a trick to charge the system, or know where I can get a 90 degree adapter (nothing like that here at the local "auto parts" stores)??? Vehicle is not licensed for the street, so taking it to a service shop would be a pain.
Thanks,
Jerry D.
Thanks,
Jerry D.
