I'm on my second LX450 and in the five years since I discovered this forum I've never had to post since everything I ever needed to know was already covered somewhere in here-- GREAT FORUM-- and thanks to everyone as you've helped me considerably without even knowing it!! However, I've finally run across a problem that I cannot seem to find the solution to... I've searched and browsed and sorted through many pages, but can't find any info about this issue.. so here goes:
my recirculation / fresh air flap won't stay closed. This is the plastic flap mounted to a mechanical arm on the blower under PS dash that closes in fresh air mode and opens in Recirc mode. All of the buttons on the Climate Control system seem to work fine and everything else is order. When in Recirc mode there are no problems. BUT, when I switch to the fresh setting, the flap closes and opens repeatedly... as soon as it hits the "closed" position it opens again and cycles like that for as long as I care to keep the fresh air setting engaged.
I took the cover off the blower and cleaned everything out (it wasn't very dirty and I didn't find any debris or obstructions). I looked behind the dash speaker / amp / engine ECU and didn't see anything jump out to me, but I got to get in there again soon to replace a bum dash speaker so if there is a relay or resistor for this single function back there I can easily replace it at that time.. anyone have any suggestions on fixing this annoyance?? I know it isn't a HUGE problem, but I do like to keep things in full working order AND this is keeping me from using one of my favorite functions on the LX-- the "AUTO" climate control setting..
THANKS!!
THANKS!!
