A 3 link FAQ?
:popcorn:I used search and found some kick butt rigs that have been built with custom 3 link front suspensions.
They are worthy of a FAQ entry IMHO for easier location in the future.
https://forum.ih8mud.com/showthread.php?t=158011
attachment.php
https://forum.ih8mud.com/showpost.php?p=2319294&postcount=51
attachment.php
That is another great one.
There are pros and cons of each I have seen.
Mounting the lower links so high on the axle required a much taller upper link mount on the axle. It did allow for good clearance behind the axle.
Looking at doing a 4" lift personally and wont be lowering bumpstops if I can avoid it. So the really tall mount tower is not what I want.
You can mount the lower links well lower than that and at the same time still have gobs more ground clearance than stock. This will require a curved lower link. Going over the tie rod then curving. For lower links I am looking at boxed and gusseted structures like what the desert guys build out of plate.
Anyone thinking about it should get a hold of the 3 and 4 link suspension calculators that were originally posted at pirate 4^2 :) forums.
The 4 link is for the rear of course.
I will be in the R&D phase for a while. Starting this spring a year spent "playing" in the sandbox will delay me. :crybaby:
Even now I am training in another state and I cant wait till the base mail guys see my ARB bull bar show shortly after T-day.
Plans are ARB front bull bar. 4x4 labs rear bump kit and homemade sliders. (I have a nice multiprocess welder at home. TIG MIG ARC etc....) Sub tank, CDL switch, OEM locker switch, regulated nitrogen system for air etc... (I am used to putting nitrogen in ACFT tires, struts and accumulators. ) When I am back and have the 4" lift -coilovers and suspension links sorted I'll figure out the tires then order gears to match and arb diffs. I will use N2 to actuate them. No h20 in air issues or compressor racket. I will run none of that stupid blue air line and use hardline wherever possible. For example m the plan is to put a hard line down the middle of the front upper arm and thread in fittings at the ends near the johnny joints. Then use a short (duh just enough length to cycle) peice of ss braided line from the fitting to the pumpkin or frame hardline depending on which end of the link it is.
I will be doing a ton of accurate measuring of the truck. I may have a body shop buddy help me out too with some data as well.
Longer arms reduce the range of dynamic caster and pinion angle. They also reduce the change in wheel base as the suspension cycles moving in a larger arc and should help in geting the most tire to stuff.
There are some very robust suspension analyer programs around. I am thinking that I may be $ ahead to just buy one of them. Getting things right on the first shot and being able to look at in action before I build it is great.
