'97 RF wheel locking up when hot
Blue Mountains, Sydney
Got a call from a mate yesterday needing help after his FTE 40th (cleanest 80 I've ever seen) decided to stop on the motorway.
Drivers front (RHD) wheel billowing white smoke, car wouldn't move. By the time I got out there with tools it had cooled down enough he could drive again, but we'd be pulling over frequently when it started to lock up again for it to cool.
Wasn't pulling to the right, but disc was definitely a bit dark when we got it home.
Wheel bearings seem ok, no noise at all when driving or spinning once it was jacked up, no play in wheel bearing.
Thoughts so far:
- Maybe ABS playing up, but doesn't seem like something that would sort itself out after cooling down.
- Old brake hose swelling?
- Water in brake hose expanding when hot?
- Sneaky wheel bearing on it's way out but showing no other symptoms?
Appreciate any thoughts, I'll send him a link to this thread to check responses.
I saw the slides, no rust there, very clean car. I'll have him check the pistons, might be clean but still 30yo original parts. He reported brakes working normally when it had cooled.
Update.
It went to a mechanic, turns out it's all four brakes locking up, all discs are glazed. Drivers front was the only one we noticed smoking, didn't check the others at the time as it was late and I had to get home.
There is a slight leak from the transfer, they suggested it was the transfer case locking up the wheels.....
He's just pointing the parts cannon at it and firing, master/booster/lines are all original 29yo parts. Calipers function perfectly fine when car is cool.
Update a few months later. At this point I'm just updating the thread in case it helps someone in future with similar issues.
He had all brake hoses replaced, issue went away. Calls me yesterday, it's done it again. Said he parked up on a slope and left her in neutral, no handbrake, couldn't even push it down the slope. Half an hour later everything cools down and it's all fine again. Something is still playing up.
- All four wheels are locking up apparently, RHD DS Front most prominent.
- Car is driven daily, didn't happen again for six weeks after replacing brake hoses. This includes long and short drives.
- When working, brakes feel great.
Pistons should be fine if they're working perfectly when not hot, but will still check when I have time to go see the car.
It's a '96, could it be an issue with pedal adjustment? Can't see how that would happen out of nowhere or why it would only happen sometimes, but who knows what's been done to the car.
Difficult to test when we can't replicate the issue on demand, might just have to go for a long drive with tools ready and wait for it to happen again.
Has it had anything done with the brake booster recently? Sounds like the booster pushrod is slightly too long which causes symptoms like you mention. no idea why it would just start doing it though.
i have seen this before. brakes are great cold and then after a longer drive they are all dragging. booster push-rod adjustment fixed it.
Can't see how that would make any difference.
Agreed.
I should have time to go have a look at the car Sunday evening, I'll check and report back.
