Hi folks,
I went through as many antenna replacement threads as I could find, but not finding one that addresses an antenna that won't go down all the way, after replacing the plastic piece (with teeth).
I made sure the antenna motor was extended all the way up, and tried to feed the new plastic piece with teeth into the motor, had my daughter press the "lower" antenna button and it grabs it but it doesn't retract all the way. I don't think re-extending and "clipping the plastic line a little shorter" is the real answer. It seems like if there was a way for me to push it in a bit further, I'd be fine, but I can't seem to push it in any further.
Wanted to check to see if anyone had any tips?
Thanks!
Thanks!
