97 lx450 mini project
97 LX450
155,xxx miles
I have owned this truck for 2 years and been lucky as I only changed the tires to 285/75/16 kenda klever M/T.
No a/c so this is why I planned to do the following.
I PLANNED for the last 2 weeks to do the following:
New radiator
New coolant hoses
New mixing valve
New condenser
New dryer
Oil change
Gear oil change
New dash lights
New fuel filter
As I got to my parents house...there was a coolant leak.
Luckily I already had all the hoses, new radiator, coolant already in the truck as I have been wanting to do this all along.
Radiator is clayish colored and gritty. I have tried flushing it in the past.
I utilized the following 2 youtube videos as reference.
I can say the 2 videos are helpful and give you a good idea what is happening.
I want to ADD if you are going to replace the radiator/condenser then go ahead and get the 3 belts, pulleys, a/c compressor and go ahead to replace those too since you are all in there already.
I did the compressor a month ago.
I bought the
HPS Black Reinforced Silicone Complete Pesky Heater Hose Kit
off amazon.
My personal opinion...just go to buy the normal radiator tubes and hoses and save money because everything is easy to replace and fast to fix ....everything...i repeat EVERYTHING except for the heater hose....HEATER HOSE I say.
First time doing this on this vehicle.
Expected time: 1 day
Actual time: 3 days - 5 hours a day = about 15 hours.
Things complete:
New radiator
New coolant hoses
New mixing valve
New condenser
New dryer
I can actually do this much faster the next time around.
Majority of the time was spent removing hoses and clamps that have been there since the beginning of time.
Many of the clamps are what looks like wraps with a pin inserted so quite difficult to break apart and they kind of melted into the hoses.
Of the 15 hours, 5 of those was spent on the PHH/heater hose:
- 1 hour: jack the truck, removing tire, locating the heater hose, cutting off the old hose
mini diagram: mixing valve > hose > metal pipe > phh/heater hose > engine
- 30mins: getting the new hose onto the pipe
- 2.5 hours: attempting to rotate and maneuver the hose/pipe with one hand onto the engine block
lots of refocusing, calming down, relaxing and water breaks to loosen tense muscles.
FAILLLLLL I failed - completely FAILEDDDD
- 30 mins: drove to auto store, bought two 4 foot heater hoses (less than $13 USD) to ensure I have the correct size.
- 30 mins: attached heater hose from mixing valve straight to engine block...bypassing the metal pipe (probably used a 2ft or just a little less of the heater hose I bought)
I ran my bypass right by the original metal pipe...the bypass hose does not rattle or wobble or by any means looks loose.
Any problems with my ghetto rigging?
I do not have large forearms or huge hands...
but it was rough...that's my left arm...my right is worse...cuts and bruises due to the PHH/heater hose...
Good cooling system refresh you have there. Just a suggestion for your ac system refresh, if you have not done with the ac system refresh yet. I do not see ac expansion valve in your list. It will be a great idea to replace the expansion valve, remove and clean your evaporator and replace all the o ring and seal in the system as well since it is opened. Then evacuate the system and recharge with Freon you are good as new, you can loan the pump and recharge gauge from autozone for free. ;)
I plan to to the A/C refresh...
Thanks for the tips!!
As I swapped the condenser and dryer I did proactively swapped o-rings....and i have the heater core ...front one i'm pretty sure...sitting on the counter...to be swapped with...
too hot in TX w/o AC
You are welcome, I can feel you I am in Houston it will be 104 for this weekend!!!
