97 Lx450 Leaning Left
Northern Ca.
Hi Everyone,
I'm a newbie with my first 80 (a used '97 LX450). I've search the forum and read quite a bit about the leaning left problem of the 80s and fixes with packers. But mine leans approximately 1.5" in both DS front and rear, which appears to be more than most people had mentioned. To my knowledge, my LX450 has the original springs, but Landcruiser shocks, 285/75/16 tires and no suspension mods or lifts.
Since the lean is more than the normal 10-20 mm range most people have reported having and fixed with the packers, is my safest option just to replace the springs? If so, any recommendations on brand or just go with the Toyota or Lexus OEM parts? I'm not looking to lift the truck (wife drives it also and she's not tall and needs to be able to put in and take out the infant carrier easily), just want to fix the lean in a safe manner. I'm not mechanically savvy so I'll need to take it to a shop for the work, any ideas on approximately cost?
Any input is greatly appreciated.
Thanks!
Calskibum
Lexus springs are known to be softer than regular Cruiser springs, same goes for the shocks. Over time, they all get what's affectionately known as the "Cruiser Lean".
I think a good set for you would be the OME (Old Man Emu) stock height replacement kit.
Slee - Toyota 80 Series Land Cruiser - OME Lift Kit details
^x2. 12 years and X amount of miles will wear them out.
OME stock height or Med's. like Lane said would be fine.
The whole kit costs just under $800, and that's if you install it yourself. What you're describing seems like very little offroad use, so you could get away with purchasing just the springs. About $166/pair from Slee Offroad.
They are fairly easy to install yourself. Trust me on that, I had ZERO experience with suspension until I installed the lift on my truck.
