$1500 all things being equal. Adding baselining remainder of drivetrain (Tranny, t-case and diffs) to an engine rebuild puts you at ~6K (you doing the work?) and brakes, bearings, front axle service could add more $. If the rest of the rig is "good condition" you would be even money at $8K IMHO.
I think it depends on your location but I think $1500 for something that may need so much work is a little high.
Remember, everything else has 230K on it too, won't be long til Karma catches up and you'll be replacing a lot more than engine parts.
As mentioned though, go through it and do all the baseline stuff, but I'd bet you're into it more than finding a good lower-miler that runs, and may even have lockers.
If you are anywhere near the Northwest, got a 1FZ-FE/ A343/HF2AV coming out of my 97 pretty soon.
195k miles, Head gasket has been done. Runs like a top. $1500 for the works.
I actually found another one locally that needs a head gasket. Everything is in working condition, engine sounds good, transmission shifts perfectly, no leaks, have some service records.
Black with tan leather, 1996, with just under 200k. I got it for $2000 and trailered it home.
I would say if you're buying this for yourself give it some serious consideration as to price....but IMO $1500 is a bit high for such high miles and considering the low resale on these trucks in running condition at the moment. I'd think something more like $1,000 or less is reasonable.
I bought a unlocked '97 a in March-Aprilish of 2007 for $3,000 with 99k in need of some motor work.
Got the head off last night. #6 piston is steam cleaned, gasket at the #6 cylinder is blown.
All valve clearances are perfect and within spec after 200k miles. Looks like the rear heater lines were leaking also. My theory is that they leaked and caused the overheat and head gasket pop.
Nice milky oil mix also. I'm going to throw in new valve seals, clean up the valves and call it a day. Should have her running next weekend!
Different truck. Should've started a new thread to avoid confusion. The rod knock one can be seen here: Cruiser
Personally, I think someone paid way too much for it.
I found a local truck about an hour away with a blown head gasket. 199k on the clock. It is a 96, black, with roof rack, and leather. The passenger knuckle was replaced 200 miles ago. I got the head off and sure enough, the gasket was blown at number 6. The head is in the shop now.
The rear heater lines are also leaking on the cats. My guess is that caused the overheating over time and the owner didn't realize it.
Either way, she should be running by the end of the weekend if I get all my parts in time. I'll start a new thread with decent pictures.
He was asking $2500 for it and I got it for $2000.
