97 Heat
NE Texas
This is a 2 part question, the first part I am pretty sure I know the solution.
The problem is that there isn't any heat in the cabin.
Here is the situation, the cable does not move when the temperature control is moved on the dash.
I have removed the cable from the valve on the firewall and moved the lever myself and still no heat so I assume the heater core needs to be flushed. I had this same problem on my 94 and found the core to be pretty clogged up, a couple good flushes solved the problem.
My question is this, how does the cable move? Is the slide on the dash actually connected to the cable or is it vacuum operated?
I have tried to gently push/pull it by hand on the firewall side and doesn't budge.
Any ideas?
Rusty
Cable sounds like it mucked up with rust, try and work it back and forth with rust penetrant or WD40 until it moves freely. ...or buy a new one!
For the heat, check the valve first, if it hasn't been moved in a long time as a result of a frozen cable, the valve itself could be clogged up with junk.
Failing that, a good core flush may solve your problem just like before.
G'luck, Dan.
So is the cable actually physically attached to the slide on the dash?
Rusty
Ok, I am finally getting around to working on my 97 without any heat!
Here is what I have done, I removed the hose on the drivers side of the valve and hooked up a garden hose to it. I removed the hose going out of the firewall to the thermostat. I ran the hose with the valve open and it spit out a bit of dirty coolant then ran clear water just fine.
Hoping the problem was solved I hooked both hoses back up and started the car, let it get up to temp, but still no heat?
Next I removed the hose coming out of the firewall that goes to the thermostat (I assume that is the way it flows) and started the car to see if the water pump was flowing anything through the heater core, nothing coming through.
So, I assumed there was something clogging it internally so I left the hose off (going to the thermostat) and hooked up the garden hose to the metal pipe going to the thermostat. I turned on the hose and water ran through the system and out the unconnected hose. I assume it is making the same path through the engine since I basically just removed the hose and hooked up the water hose. I did have the engine running but water flowed through the heater core just fine with the water hose hooked up.
Again hoping the problem was solved, I removed the water hose and ran the engine to see again if the water pump would flow anything, again nothing!
Am I doing the flush correctly? I would think it has to be going through the engine since I basically just spliced into a hose and forced water through. It wasn't a closed system since I was letting the water pour out but still it should have been flowing through shouldn't it?
Now back to my other question, the cable is stuck, I haven't tried to force it, should I? I am pretty sure it is not a direct connection to the control on the dash (wish it was) but instead either vacuum or electronic?
Any ideas about either of these? It is going to be getting cold soon and my son is going to need the heat!
Rusty
I have been messing with a similar problem on my 94 I have flushed the heater a couple of times with the water hose method and I am still not getting heat. My valve is functioning properly and getting plenty of heat from the rear. We may have a similar issue although I dont have an answer. Let us know if you figure it out.
thanks
Does anyone know how the water flows through the heater core and rear heat? It looks to me like it comes through the valve then to the 2 heater cores. There are 2 hoses that come out of the firewall then T into one hose going to the water pump. It seems like the only possible way fj80toyman could be getting heat out of the rear but not the front is for water to be flowing through it and not the front which means the water must T before the 2 cores, otherwise the hot water would have to flow through the main core to get to the rear core?
Anyway, I don't think this is my problem. I can remove the hose going to the valve, turn the engine on and no water flows through the hose that should be going into the valve which means something is blocked. But I can force water through it with a garden hose just fine?
Somebody must have some ideas, it is getting cold here this week!
Rusty
I've not read this thread till now and don't have a complete answer but something was alarming me here. You're starting the engine with the cooling system open multiple times here and I'm concerned about you damaging the head/block/head gasket due to thermal shock of putting cold water in and doing these various things.
Here are my thoughts:
If you have a siezed cable, you are not moving the valve to get heat to the rear heaters, right?
If you've not filled the system with the heater valve fully open (full hot position), then the system has huge air gaps in it which would explain the water pump's inability to circulate water when you're starting it with hoses off to watch if water comes out.
The FSM has a great diagram detailing where the water flows at all major points. Can't recall where exactly but I think it's the cooling system section.
Remember that if you're doing all this work on a cold engine the thermostat is closed, preventing circulation beyond a dribble except in the engine block itself.
So. I don't know any other way to say this but you need to understand a bit more about the engine's cooling system or you risk damaging it.
Park it nose high with all hoses attached and fill it from the radiator with the engine off and the water valve open (heat at full high with the key on so it powers the cable operated valve - otherwise moving the heat lever on the dash does nothing without power). And if this cable is indeed siezed (never heard this on an 80 ever) then pull the tip of the cable off the water valve and move it yourself. BTW if you've been trying to move the cable from the engine bay and interpret your inability to move it as seized - I hope you haven't damaged the mechanism as that's not supposed to move that way. Only with the dashboard's system. When the radiator has refused more water (just do this with water so you know if you've solved the problem) go have a cup of coffee and read the paper. Come back in 20 minutes and put some more water in it. Fill the overflow, then start the engine and after it's warm enough you're getting heat from the dash vents (now the thermostat's open) rev the engine to 2500 or so a few times to get the remaining bubbles through. Check the rear heater's also getting heat by turning on its fan.
If all is working normally, open the block drain (not rad drain - block drain) and pull the lower hose and drain the system. Refill with coolant mix.
DougM
IdahoDoug, thanks for the replies, let me see if I can answer them.
First the cable does not budge, I have not forced it because I am pretty sure on the the 95-up's they are electrically or vacuum controlled, either way I would not want to force it since there isn't any sign of corrosion that would be causing it to stick. Because of this I disconnected it from the valve and opened the valve by hand.
Next I flushed the heater core until the water flowed through nice and clean. After this after this I started the car and let it run until the engine heat came up but was still not getting any heat in the car (valve was still open).
After this I assumed there must be some other blockage so I let the engine cool and did a backflush to see if I could get water to flow through the entire system. I wasn't sure it would work with the thermostat closed.
I hooked up a hose between the thermostat and the firewall and forced water towards the water pump through the engine, water flowed nicely through the metal pipe coming from the heater cores so I am assuming if it made it all the way through the engine to the heater cores with the garden hose it should be able to do the same with the water pump.
After this I decided to see if the water pump would indeed push water through so I removed the garden hose and started the car, nothing came out?
Anyway, I haven't progressed much beyond this point, I am going to work on it again this weekend but it seems to me it should be working.
I am also going to pull the dash panel and see why the cable isn't moving.
Rusty
Rusty,
Why do you say the cable isn't moving? With the key on, and moving the temp lever on the dash, does the cable NOT move? I'm just trying to establish that you'd be the first ever to have this issue. Also, how did you establish which way to move the heater valve lever to open it to full hot?
I still think all is well, just trying for some clarification.
DougM
I don't know if this will help but...
There are 2 heater cores, front and rear. Did you flush them both?
No heat can actually be caused by a stuck thermostat too - and it is probably due for one. Did you replace the thermostat? Don't use a parts store special on this one - use an OEM part. Make sure you get the jiggle valve oriented right.
Did you drain the block and radiator using the block plug and petcock respectively? If you're flushing it, may as well flush it all.
When filling, my preferred method is to cut the top off of a distilled water jug (milk jug - if washed REAL well) then use that as a funnel. Disconnect the top radiator hose (Driver's side US) and fill directly into the block until that is full, connect it back up and finish-fill through the radiator then half fill the overflow. Since you will have disconnected the heater cores, there will be a pair of big air bubbles to work through. Run it with the radiator cap off and top it off as you can.
For base-line on both of my trucks I did tap water 3-5 times then 2 fills with distilled, made sure everything was happy THEN did it again with 1.75 gallons of Toyota OEM red coolant, top the system with just under 2 gallons of distilled THEN put the .25 gallons of straight coolant into the overflow. Yes, that stuff is $28 a gallon.
Have you changed out all of the hoses and the PHH yet? System is drained, coolant is expensive - makes a great WYIT project.
IMHO YMMV I'm not a mechanic.
Four speed.
IdahoDoug, I am pretty sure I have tried the heat with the engine running, I move the slide lever inside the cabin and the cable on the firewall does not move? I can't believe I am the first but I guess someone has to be.
I found out which way was full open by removing the hose on both ends of the valve and flushing water through it.
Grench, I am aware there are 2 heater cores and think I flushed both of them. I looks to me like they both come out of the firewall and "T" into the metal pipe going to the thermostat. All I know is I got water going through that "T". Is it possible the water is just going through the rear core? I assumed water went through the front one then into the rear one but now that I think about it there wouldn't be any need for 2 return hoses if this is the case? How do I get water into the main heater core only? I guess I can pull the hoses off of both pipes coming out of the firewall to see if I am getting water out of both.
I am still wondering why I am not getting any water to flow to the valve? I can force water to the valve and through the heater core but with the engine running nothing makes it to the valve? Is it because I have the hose removed? Does it have to be a closed system to force water through? The only place I have it open is the hose going into the valve just so I could see if water was making it there.
Thanks for the replies again, I am going to get out this weekend and try a few more things mentioned in this post.
Rusty
Rusty
Here is a good thread about how to go overboard with flushing this - if that's possible:
https://forum.ih8mud.com/80-series-tech/14891-cleaned-my-cooling-system-full-scoop.html
The rear heater core does -not- pass through the firewall. It runs down and back through the transmission tunnel, over the catalytic converter then up and into the body from underneath. It is a pair of hard lines. They connect at a T before the front heater control valve and the return line comes up to join with the underside of the cab return line right after it passes the firewall.
As for your valve, get a foot or so of 5/8 silicone heater hose and a box of fully sleeved clamps from Napa and a pair of dikes. Thats a pair of cutting pliers commonly used by electricians.
Cut the clamps on either side of the heater valve. Look through it and push the lever back and forth. It's a ball valve - it either works or it doesn't.
Did you ever change that Thermostat? Seriously - they DO die eventually. Neither of mine has the Thermostat they left Japan with.
I have a 97'. As far as I know the cable is controlled from some kinda of electronic motorized unit. When I move my switch I can hear a motor operate. It seems to step the cable along as I slowly move the heat slider.
Chris
Grench, I have already established that the valve is working, I removed the water hose going into the valve and removed the hose after the valve. I then hooked up a water hose to the valve and ran water through it, I can manually turn it off and on so I know it is working. Water comes out the "T" past the heater core so I am pretty sure I have water coming through the heater core.
I have not replaced the thermostat but will check it this weekend.
I will also check to see if there is any rear heat but the real puzzle to me is the fact that water is not flowing to the valve?
Rusty
Search for a thread I posted from about a month ago on flushing the front and rear seperately. Someone posted a link that helped me figure out how to flush each individually, which I did. Although still no heat form the front.
thanks
Ok, I hope I have it figured out. I was off work this afternoon and when my son got home from school I popped the hood and took a look. First thing was to check to see if it had rear heat so I turned on the rear heater and sure enough there was hot air coming out! This made me think that I must not be be getting the main heater core flushed. So I took a close look at the hose routing and it appears that there is a "T" after the valve which makes me think that you can not flush both cores at the same time. I started thinking what a pain it is going to be to get to the hose after the valve going into the main core but then I realized the return lines coming out of the firewall are pretty easy to get to, so my thought is to plug the hose coming out of the rear core and that would force the water to flow through the front core.
This is my plan, if anybody has any reason why I shouldn't do it that way please let me know!
Will let you know how it goes.
Rusty
An old plumber once taught me:
Payday is Friday.
s*** flows down hill.
Every pipe has two ends.
All very true - and very applicable in nearly any line of work.
