My starter has had an issue for awhile now. It would occasionally sound like it was "grinding" and wouldn't start the truck. This was most repeatable with a high draw set up (lights on, a/c on, blower on high). I replaced the battery with a Sears Premium thinking it was low voltage. It still occurred, but was more rare. I then replaced the starter contacts (twice) thinking that might help. It still occurred on occasion. Mostly, I just made sure the lights and a/c compressor were off when I started. Troubleshooting this AM, I found that if I hit the starter and turn the car off and try the starter again, I just get a click. I had to wait a couple minutes for the truck to be able to start. I pulled the wire from the ignition switch and measured 11.95 volts with no load (11.76 volts with lights and a/c on). The power cable to the starter is properly torqued. All the battery connectors seem good (and the voltage needle doesn't dip any different than when it starts). I've never messed with the engine grounds so I'd think those are okay. The vehicle has no other electrical problems.
I'm thinking my next step is a new starter. (It is currently my only driver, so I'm limited on my troubleshooting). Reasonable next step or am I missing something?
Thanks...
Thanks...
