97 axle stuff into a 94
Can anyone confirm for me that front axle parts from a 97 will fit into the axle of a 94. Things such as birfields, etc. Thanks.
yes they will, although the splines on the later style birfields are a little bit longer..By milimeters if I recall correctly...
The axle will physically fit into the 94. Birfs and splines should be the same with exception of whether or not it's locked. If it's locked then it will be different - you will have to talk to Dan about the specifics.
