'97 1FZ-FE freeze plug diameter?
Englewood CO
Title asks it all. I would like to find out what the diameter of the freeze plug you would remove, US DS front, I believe, to install a block heater. Anyone know? I had no luck with search and finally gave up and figured I would just ask.
TIA
When I got my block heater from the local parts dealer they looked up which heater I needed based on vehicle year and engine. Let the computers do the work of figuring out what size you need.
I did. At Napa. Then got this:
"The part number BK 6051454 is out of stock and not available due to a factory backorder. The supplier was not able to estimate a time frame as to when the part number will be in stock next. "
So, I am trying a different route and need to know the diameter.
Thanks!
Rich
IIRC I have read in one of the threads that it is 40mm. I have a block heater sitting on my counter but I don't have a tape measure handy and it's almost 2AM.
Ideally I would need a caliper to measure it, but I will try to get a rough measurement for you.
Until then you might be able to call your local dealership and see if they know.
