96 engine swap
I might be wrong and others can chime in but I think it might be a little problem since the 95+ is OBDII and would have different sensors. At the very least, all the sensor plugs are different. Unless you're looking for a challenge, I would swap with an identical engine just to avoid problems.
Lots of differences on all the accessories, sensors, etc, but from what I know, the actual engine block and head is the same.
As others have stated, the earlier (mid-1995 or so and earlier) are OBD which means different computer as well as different tranny (A343F vs. A442F: fully electrical vs. a semi-electrical/semi-mechanical respectively). The later trucks have 2 knock sensors as opposed to the 1 of the earlier 1FZ's.
Earlier 1FZ's have a different air meter/intake tube. The block and heads are similar--not the same.
Most of the other stuff is the same. I would talk with someone like Robbie or CruiserDan to get the specifics of the differences. They can elucidate all of them.
A 3fe swap........awesome!!!!!!!!!!!!!!!!!!!!!!
