96 Cruiser randomly wont start
I have a 1996 Land Cruiser that randomly won't start. Just throwing this out there, ...it started doing this after hubby sprayed down the engine. Wouldn't start. Several hours later it finally started up with a lot of patience. Every time it hasn't started up it was either raining or very damp out. Could be a coincidence? Anyway, the battery is new. It is getting gas. The check engine light came on about a month before my problem began... Son in law checked the error and he said he thinks it probably needs a EGR valve. . been waiting since they sent the wrong EGR first time around. I am wondering. Could that be connected to this problem or is there another cause of this problem?
To add to the woes, the other night a family member tried to start it up and it just wouldn't so she (yes, teenage daughter) turned and held the key ...starter cranked until the Cruiser started. SIGH. LUCKILY she didnt burn up my starter.
Have any answers?
Moisture is getting into an ignition component. For now, get a spray can of ignition protector and spray all of the distributor and wire plugs.
Time for new wires/plugs/distributor cap.
Courtney...
good info above....... also make sure your battery cables are clamped tightly on clean terminals and check for any shorted cables or wires in the fusible link (small wire bundle (3) off the positive terminal by manipulating the wires while the motor is running. best of luck
Could that [CE light] be connected to this problem or is there another cause of this problem?
I agree the starting problem sounds like water got into the distributor (aka dizzy) but that is really the only clue you've given us so jumping to that conclusion is all we have.
The Check Engine (aka MIL) light is not related to the problem. If your SIL suggested an EGR valve then you probably have a P0401 code. This is a very common problem with the 80-Series; especially the 96-97 trucks because Toyota "tweaked" the computer in the later years. Do some research on the P0401 because it DOES NOT MEAN YOU NEED A NEW EGR VALVE. In fact, it is fairly rare for the EGR valve to fail. More than likely your vacuum tubes or the VSV for EGR have failed. Sometimes it is the EGR modulator and on rare occasions the code is cleared with a cleaning of the EGR temp sensor. Don't go on the above as gospel; the P0401 is the most cussed and discussed of all the OBD-II codes we have seen on the 80-Series. There is a lot of information here on 'Mud.
What is the mileage and prior engine repair history (e.g. tune-up) on your truck?
-B-
THANKS SO MUCH!!!
Dont know much of the history... this truck was purchased from a guy who we later found out scammed a little old lady out of it. SIGH. Anyway, we got it from him and turned him in, got to keep the truck.... put a new battery in to get it home, found the radiator was a bit rusty and we tried flushing. Think we are going to replace the radiator tomorrow. BTW, that was the reason hubby washing down the engine. He was flushing the radiator at the time. Then we will try the suggested fixes and work our through to solve the problem. Will replace wires / plugs /distributor cap ASAP. The vehicle had 204k when we got it. It has 206k now. Planning on keeping it. The truck is very nice in & out aside from these two issues.
Another thing that was odd, my teen daughter said she heard faint fluid gurgle and then the check engine light went off. It hasnt come back on in having been driven about 25 miles / 3-4 cruises in the vehicle.
To assist with the MIL, we need the precise code, not a translation of the code.
-B-
When my engine gets sprayed directly with water it causes the cylinder closest to the firewall to misfire. It also tended to be very hard to start and threw a code causing the check engine light to shine. All of this went away when the water evaporated.
You can buy a scanner tool from sears pretty inexpensively and it will tell you what codes are stored in your ECU. Which is precisely what Beowulf is suggesting. We have to know which codes are saved in the ECU so we know how to help you. Since it isn't starting like it should and generally shouldn't be driven the best course of action is to buy a scan tool and read the instructions.
We are anxious to help once we know what the code is. :D
