95 L/C help requested
Newbie here.
I have a 1995 Land Cruiser that all of a sudden started bucking. Hitching and hesitating badly. Idles very roughly then dies out. Limped it to my mechanic and he is lost. Plugs, wires and fuel filter were replaced. Fuel pressure was supposedly fine. He did not know what the psi is supposed to be exactly. He is suspecting the MAF unit or oxygen sensors (locations)?. Need some ideas/suggestions on how to fix or troubleshoot. Mechanic is stumped on this one. ANY help is appreciated. I miss driving it.
OK, lets say there's no blown fuses or MIL on, one of the first places I'd look is the wiring harness as it runs behind the EGR valve (near the cowl) hard to get to and you need to REALLY take a good look at it. The problem is that the heat from the EGR sometimes melts then shorts wires out in that bundle. Depending on what wires, depends on the problem you are experiencing.
I'd also have a look at the condition of the catalytic converters, a plugged one might be causing this symptom. Check that the connection to the Air Flow Meter is good and solid as well as the connectors on the throttle body.
And if you're going to own if for awhile, get a Factory Service Manual and lend it to your mechanic when you take it in. Worth it's weight!
Dan.
Thanks
I hear ya on the manual. Still kicking myself for not having one. Will remedy that situation asap. If for nothing else, i will have an idea on WHERE everything is. Will pass on your recommendations to my mechanic.
