Does anyone know if the BRE exhaust and magna flow catalytic converter Y pipe will work on my 94 exhaust manifolds?
I did a search, but I guess I didn't find this exact combination with a 94Try searching there is lots of threads on this. The Magnaflow will bolt right up.
PAIR is deletedif you have a pair valve delete you can put the o2 sensors in there, if you don't you will need to add bank 1 and bank 2 o2 bungs, then cap of the combined o2 bung that 95+ uses.
Thank you! I actually have block off plates for the manifold that I made and I can just transfer them to the Y-Pipe. Building a test pipe after the cat should not be that big of a deal. Somebody had deleted the cats on my 94 at some point.Install O2's in exhaust manifold holes left from PAIR delete, weld up/cap off O2 hole in magnaflow Y-pipe. 95+ have a second cat inline so you will need to add that cat or make a short section of exhaust to connect the Y-pipe to the Brexhaust. The Brexhaust will go under your frame not over the frame like on your 94. But yes it will work with a little work.
